Rear Lower Control Arm Question
So I recently bought a set of coilovers for my 1997 Honda Civic and I had installed 3 of the coilovers earlier but I came across an extremely rounded bolt that holds the shock and the lower control arm together. I tried everything to get it out and I think the bolt is seized into the bushing at this point and I don’t wanna bother trying to remove it anymore.
I know those bolts tend to get rust welded and seized up anyways, so I was wondering if I could just remove the entire control arm with the shock still attached to it and replace it with a new control arm and install the coilover from there. Would this work? I had already removed the top hat bolts from the shock as well
corkss
10
Mar 19, 2009 07:00 PM
ActiveAero
May 14, 2006 10:22 AM
