brake system problems.
Old Apr 13, 2025 | 07:41 PM
Andre Freire's Avatar
Default brake system problems.
Good evening, my name is André and I'm from Brazil. I have a 1993 CR-X. I'm having problems with my Honda's brake system. The brake fluid is leaking from the master cylinder reservoir to the ABS reservoir. I don't know what could be happening. There's no ABS fault light. However, I need to drain the excess fluid from the ABS reservoir and return it to the master cylinder reservoir weekly, otherwise air gets into the system and I need to bleed it again. Everything works correctly, but I'm having this problem. Could someone help me? Thank you very much.
malilaz
Suspension & Brakes
Nov 23, 2013 12:42 AM
choppyEG
Sep 21, 2013 05:15 PM
95GSRBOI
Nov 14, 2012 03:55 AM
i97supratti
Apr 9, 2011 10:42 AM
Lou_p
Jun 10, 2007 06:54 AM
