Rhd eg hatch with dc2 dash. Lower dash panel fitment
Good evening. Finishing up a long project on the hatch and haven had much luck in an answer. Fairly new to Honda tech. I have a rhd eg hatch with a dc2 dash. Question is will a USDM lower dash panel fit in the rhd dash? I already have the rhd center console with I have to find out the hard way usdm didn’t fit. And what steering wheel column cover do I use a well. Any help would greatly be appreciated. Heading to scrap yard in the next couple days to gather up a couple more interior pieces. Thanks again in advance.
Ok no problem. What about steering column cover. Integra or civic? I put my civic one on and it fits but don’t no if it will actually fit once the lower dash cover is one
Since the key switch is still on the right side of the column... LHD column covers may work fine. I don't own any RHD Honda's so I cannot tell you for sure... but since you already have Civic column covers, it wouldn't hurt to try. Please post your results for others who find your post in the future.
So I did try the civic column cover on there and the 2 front screws screw in but the 3rd back one does not so I will need an integra column cover. As well the civic column cover is also longer on the bottom so the bottom panel wouldn’t not fit with the civic column cover
I was afraid of that... as well as the openings for headlight/turn signal and wiper stalks... they are backwards from a LHD, so the openings may not be the correct size.
What column are you using? The plastic pieces need to match the column.
The openings for the switches won't matter. You can trim the opening bigger with a dremel. I've done it on the EK.
