Transmission (automatic) issues 94 dx
Old Mar 24, 2025 | 08:13 PM
94dxf22b's Avatar
Default Transmission (automatic) issues 94 dx
I just bought a 94 dx with the 4 cyl I have a blinking d4 light but no check engine light when I put the car in reverse it catches just fine and backs up right away move it to neutral and it continues to reverse same with d4 and d3(although sometimes it catches if you give it a few seconds) 2nd catches most of the time and 1st catches almost every time
when taking off you have to gradually gas it or it just revs and doesn’t take off(I’m not sure if this is limp mode or what considering it barely moves from 0) I’m not sure if it’s the tcu, torque converter, shift solenoids, or just the transmission
the transmission also has clean fluid and doesn’t leak if anyone has experience with this problem or any info that would help it would be highly appreciated
Old Mar 26, 2025 | 07:21 AM
Aradin's Avatar
Premium Member
Default Re: Transmission (automatic) issues 94 dx
If you have a blinking D4 light then the TCU has fault codes. Pull the codes and it will point you in the direction of the issue(s).
Old Mar 27, 2025 | 05:03 AM
94dxf22b's Avatar
id it the same as pulling the check engine light?
because I shorted the little connector to see if their were any codes but I didn’t get any codes
i also tested solenoids and they were good
Old Mar 30, 2025 | 10:41 AM
Aradin's Avatar
Premium Member
Yes. Using the 2 pin connector underneath the glove box. If the D4 light is blinking you have active or stored TCU codes, try again. You have to count the blinks when you jump the connector. Long blink = 10, short blink = 1.
Old Mar 31, 2025 | 10:08 PM
A96ccord's Avatar
Just Manual swap it.
The engine will be happier
Old Apr 19, 2025 | 10:49 AM
MAD_MIKE's Avatar
MM Gruppe B
Whe turning ignition to II(ON) does the CEL lamp illuminate?
If that bulb is burnt out or removed then you will not be able to retrieve codes.
Not all transmission related codes will show through the D4 lamp.
96civic909
Sep 11, 2012 06:22 AM
jmacsss
Sep 27, 2011 12:01 PM
Marcpb443
Oct 6, 2009 08:52 PM
slammed94ferio
Northeast (Sales)
Jun 9, 2007 09:00 AM
