Can you change the Coolant Temp sensor on ZC without draining coolant?
Old Mar 23, 2025 | 04:55 PM
Azthioth's Avatar
Default Can you change the Coolant Temp sensor on ZC without draining coolant?
Got a D16a9 and I think the CTS is bad or going bad. I want to try and change it but don't want to drain the system if possible. This doable? Any tips?
Old Mar 23, 2025 | 06:34 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Can you change the Coolant Temp sensor on ZC without draining coolant?
Yes, some will leak out, but it is not necessary to completely drain the whole system to swap the sensor. Just have the new one close by and ready to thread into the hole when you remove the old one.
Old Mar 23, 2025 | 06:40 PM
Azthioth's Avatar
Am I looking at it pouring out or will it be a bit? Trying to figure out how fast I need to be lol
Old Mar 23, 2025 | 06:43 PM
AydenA20's Avatar
5 Year Member
If you let it sit overnight it will probably leak out less than if you drive it into your garage right before working on it. Either way, it shouldn't leak a ton.
Old Mar 23, 2025 | 07:00 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Wait for the engine to cool down to ambient temperature for sure...
Then, remove the sensor with one hand and stick a finger in the whole with the other hand. Swap sensors with the first hand, then re-insert the new sensor as you remove your finger from the hole. Some coolant will leak out, but it will be minimal with this method.
GeneBEllis
May 10, 2013 05:44 PM
holmesnmanny
Dec 19, 2011 10:40 PM
theeogflip
Aug 8, 2008 12:05 PM
scratchline20
Jul 29, 2003 01:40 PM
