1320 motor mounts b16
Old Mar 21, 2025 | 07:06 PM
Spaz253's Avatar
Default 1320 motor mounts b16
Installing passenger side motor mount but only one screw will tighten the other 2 won't, is there a specific order you're supposed to screw them back in? is one bolt fine looking for advice... driverside is fine
Old Mar 23, 2025 | 01:29 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: 1320 motor mounts b16
you mean the threads inside the holes are reamed out. Doesn't matter if you have Hasport, Innovative, 1320, Temu, etc....
Fix that before you start driving the car. It will not end well when the tranny drops...
Old Mar 23, 2025 | 01:55 PM
Spaz253's Avatar
No just couldn't get it to line up so only one bolt in it, gunna take to shop hopefully. Not sure what else todo
Old Mar 23, 2025 | 02:32 PM
NVturbo's Avatar
O.G. triple O.G.
you mean the "pre-driilled" holes are misaligned. That's why you stay away from cheap mounts.
Old Mar 23, 2025 | 03:08 PM
zPandamoniumZz's Avatar
10 Year Member
Theres no specific order. I used Hardrace ones and the gearbox side mount was one of the easier ones. Like @NVturbo said, steer clear of cheap parts. Its never 'bolt on' with them.
matpl500
Feb 27, 2011 02:29 PM
shoklid
Dec 12, 2009 09:19 AM
CRX30436
Mar 17, 2008 03:23 PM
95JDM
Nov 17, 2007 02:46 PM
