Tucked engine harness eg questions
Old Mar 17, 2025 | 07:47 PM
egriley's Avatar
Default Tucked engine harness eg questions
Hi i am currently having some issues with my engine to chassis harness. I have a 95’ civic ex with a b18a1 and LS trans in it. I’m trying to put a madhornets tucked engine harness in but wont seem to connect to the chassis harness. So how am i supposed to do this? I can only find stuff about eks and not egs. Do i need a jumper harness? Anything helps thank you!
Old Mar 18, 2025 | 07:29 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Tucked engine harness eg questions
Tucked engine harnesses are not usually chassis specific... so integrating them with YOUR chassis typically requires the use of a "Conversion Harness"... and these should be from the same company who produced the tucked engine harness. Sometimes, they will come with a "flying lead harness" which will require wiring into your chassis instead of a "plug-n-play" solution.
You need more wiring to make it work.
ENDLESS9
May 5, 2014 08:43 PM
zdiddy22
Oct 14, 2013 08:51 AM
crxhybrid1320
May 26, 2010 02:28 PM
Hittnthebz
Dec 20, 2007 06:13 PM
ENDLESS9
Feb 4, 2004 09:38 PM
