91 crx si seatbelt light not turning on
Old Mar 13, 2025 | 05:52 PM
perfecteg's Avatar
Default 91 crx si seatbelt light not turning on
Hello,
The seat belt lights on my crx wont turn on. The driver one on the cluster and the rear view mirror
Anyone have any idea how to fix it?
So far I tested the bulbs are good, theres continuity at the to the buckle and the buckle works too.
Where do I start testing for continuity at the gray box behind the passenger dash? I think thats whats broken. And if I can figure out which wire goes where I can just jump and bypass the box
Old Mar 13, 2025 | 07:16 PM
GeoMetry's Avatar
Loved
Community Favorite
10 Year Member
Default Re: 91 crx si seatbelt light not turning on
I'm confused, do you want to fix it or bypass it because those don't seem like the same thing. I thought the seat belt module was a metal box on the passenger side of the heater core enclosure. When you describe it as a gray box I start thinking about the gray plastic ICU box but that would be on the drivers side not the passenger side. I can tell you that in a stock 91 CRX the ICU (the grey box behind the fuse box on the DRIVERS side dash) has nothing to do with the seat belt system. There are PDFs of the service manual available for download from the internet. That would contain the wire diagram and that is where I would start.
Old Mar 14, 2025 | 09:24 AM
perfecteg's Avatar
I dont know what to fix. The passenger light on the rear view works. If I disconnect the seatbelt control module(gray box on passenger side near heater core). The passenger light stops working.
So my next step is checking for continuity there. If the box is the problem I think I can just jump the pins to get power to the bulbs. I dont know which color wires I would jump together though
Civic2bBuilt
Jun 30, 2011 09:16 PM
92civeg
Dec 20, 2005 07:37 PM
elmalouno
Aug 10, 2005 04:50 PM
