Intermittent crank no start 95 dx
Old Mar 6, 2025 | 09:38 AM
Logansmith's Avatar
Default Intermittent crank no start 95 dx
Really struggling. Had an intermittent no start on my 95 civic dx. About a month ago the car would have a crank no start and the CEL would not go away. I noticed that the main relay wiring harness was chewed up bad and I replaced it and the main relay. The car then would not start till after I hit it with starting fluid. And acted fine ever since last night. Then I got in the car and the cel didn’t disappear and had the same crank no start. I hit it with the fluid again and it just coughed. Any recommendations? I did replace some grounds as well but no dice.
Old Mar 6, 2025 | 08:14 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Intermittent crank no start 95 dx
The "Check Engine" light staying on is a common symptom of ECU failure. Try a "Known Good" ECU to start the car... ANY OBD-1 ECU will do.
Timothy Yhtomit
Dec 10, 2020 03:36 AM
TonyBlaz
Feb 12, 2009 08:48 AM
team 15
Jul 19, 2007 09:34 AM
jwhella
May 7, 2007 07:54 PM
89sicivic
15
Jun 1, 2006 07:51 PM
