Fuel gauge always past full
Old Mar 6, 2025 | 09:25 AM
hammergunner's Avatar
Default Fuel gauge always past full
So I've been having this problem intermittedly for about maybe a month now I went ahead and replaced the cluster that wasn't the issue went ahead and replaced the float and that wasn't the issue so now all I'm left with is the wiring anybody have the diagram?
Old Mar 8, 2025 | 02:13 PM
oscar489's Avatar
Default Re: Fuel gauge always past full
Your sending unit is grounded out whether by bad wiring or being hooked up wrong. Very possible the previous owner didn't know what they were doing, start there and get a wiring diagram from Honda or a repair manual.
Old Mar 8, 2025 | 09:00 PM
kilofoxtrot's Avatar
Old Mar 27, 2025 | 08:50 AM
Is the black/white wire just ground?.
and the yellow/white wire had 2.4v on it
Old Mar 27, 2025 | 10:29 AM
Affirm…black is ground. I’m not sure what the voltage would be as the sender transitions from 5 to 105 ohms. I’d image it should still be 12v, though. Shouldn’t be a drop across the gauge. The change in resistance should just change the current flowing through the gauge, changing the magnetic field and moving the gauge accordingly. I’ve been wrong before once, though…😁
Sea
Jun 27, 2023 05:55 AM
sidewayz
Sep 22, 2013 09:28 AM
FloMotion
Apr 8, 2013 07:50 PM
SpEcIaLkOuPe
Apr 25, 2009 12:58 PM
B-SerioUs EGg
Jan 12, 2006 02:03 PM
