JDM B16a Mystery Idle Issues and Code 22
Old Mar 5, 2025 | 02:29 PM
Treble_Forte's Avatar
Icon4 JDM B16a Mystery Idle Issues and Code 22
Hey all! Just wanted to preface that I am not super knowledgeable on car repairs, but I am learning as I go by scouring forums and YouTube videos. With that said, I have been dealing with a particular issue that I can't seem to get an answer for and have joined to see if anyone can help me troubleshoot. I have a 1995 Del Sol with a JDM B16a and P30 ECU, and the main issue is that I can't get rid of a code 22 and bad idle. Probably going to be a lengthy post, but I want to include any information I can provide that may be pertinent.
About a couple months ago, my Del Sol started to have a serious issue. I was driving on the freeway for about 45 minutes, pulled into town, and after the first stop light, my car started to seriously bog down and lose acceleration power before dying on the side of the road. There were no signs of issue or overheating when driving it. Once on the side of the road, it would not start up again at first, but after some time and letting it sit, I managed to get it started again. Drove it for about a block before the same thing happened again and it died. When it is running at idle, the idle seems to start normal before it dips down to about 1000 RPM and then under 500 RPM and acts like it's about to die and then catches itself to continue barely running. If left sitting at idle, it will loop between 1000 RPM and under 500 RPM constantly for a while before eventually just dying. Tried to test the battery to see if it was possibly related to the alternator, but everything seemed fine. When checking the error codes, it came up with code 7 and code 22.
Since I was far from home, I took it to a shop to get looked at. They were unable to find anything to confirm what the issue was with the idle. They replaced the TPS and calibrated it, which removed the code 7. They thought it was related to fuel issues, so they checked the fuel filter and replaced it. They also cleaned the IACV out. They said the old filter was pretty bad, and the IACV was pretty dirty, but getting those taken care of didn't resolve the idle issue. After a color test, they did confirm that there was a head gasket issue, however. I was experiencing pressure issues with the coolant being forced from the radiator into the reservoir. I was not experiencing any overheating issues though.
Me and a buddy (who is much more knowledgeable on cars) ended up doing the head gasket repair ourselves. First, we took the head to a shop to get rebuilt. Once completed, we got everything put back together and it seemed fine at first. No more coolant pressure issue at least. After checking the VTEC plugs, we found that the wires had been oil damaged and broke apart. We replaced the VTEC solenoid, as well as splicing new plugs to replace the damaged ones. I had replaced the VTEC solenoid about a year prior, so the sensor shouldn't have been the problem, but I ended up replacing it again just in case. Also replaced the IACV with a new one just in case that was causing any potential issues. The knock sensor was also broken, but I wasn't receiving a code 23, which was odd to me. This was also replaced. I drove home on the freeway for about 20 minutes, but once I hit the first stop light, the idle issues began again and the car died on the side of the road. Pretty sure this time when attempting to get it driving I heard a misfire. Fuel pump engages normally. Had it towed to a nearby shop, but they couldn't figure it out other than saying the code 22 meant the VTEC solenoid was bad and they wouldn't do anything else to try to fix the issue. They also weren't able to do anything electrical, so I couldn't get any further help.
After all this, I am still receiving the CEL code 22 with the same idle issue. I have tried to check if it was related to the wire from the ECU to the sensor, but it seems like it is fine. I've tried replacing so many parts to get rid of it, but nothing seems to work. Shops can't seem to help either. Only thing I can think is that maybe the ECU is bad somehow? I've heard moisture is a common problem with it, but I live in CA where we don't get a lot of rain so I can't confirm if that's what happened here. I'm hoping I can get some kind of answer as this is my only vehicle and need to get it working by end of the month. Any assistance or suggestions, with helpful explanations or guides if possible, are appreciated!
TL;DR of issue and repairs:
Del Sol B16a code 22 with bad idle and losing my mind trying to figure it out. Idle starts fine before dropping under 500 RPM and back up to 1000 RPM constantly before dying.
Driving can be done, but the idle can cause the car to die when starting from a stop light.
Rebuilt head and did a head gasket repair, timing, etc.
Replaced VTEC solenoid, TPS, IACV, knock sensor, plugs connecting to VTEC solenoid.
Basic electrical tests with multimeter to check ECU to VTEC.
Again, sorry for the lengthy post!
Old Mar 15, 2025 | 06:15 PM
Default Re: JDM B16a Mystery Idle Issues and Code 22
Got the ECU capacitor repaired and the car no longer pulls code 22. However, the issue still persists. If I get to high enough RPMs, the car will then throw code 21. The car seems to start up and run better when cold, but as soon as it starts to warm up, it gets worse with the poor idle issues. I decided to check the ECU backside and noticed there was a wire going from pin D6 to another spot around where the bad capacitor was. Does anybody have any idea why this was done? I checked online and see that D6 is the VTEC pressure switch, but no idea where it is going to.
loyalgargoyle
Feb 27, 2023 08:11 AM
aksdgff
Sep 3, 2010 06:14 AM
b18cisbetter
Dec 8, 2009 06:04 AM
sevenfc
45
Oct 15, 2009 03:52 AM
lechuza05
Apr 12, 2006 07:50 AM
