Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Sluething a Burnt Compressor Field Coil
Old Mar 5, 2025 | 10:22 AM
lothian's Avatar
Default Sluething a Burnt Compressor Field Coil
2005 Odyssey
I replaced a non-functioning compressor field coil July '24. Smash cut to this week and wifey complains about warm air at the first hot spring day. After the usual cursory steps, I determined that the seven-month-old field coil is indeed bad.
In between these two dates there were two events:
- last Fall I replaced a noisy idler pulley, along with the belt and tensioner; and,
- mid-winter I replaced the A/C compressor pulley after its bearing failed violently; I swapped in a new clutch at the same time.
Then this week the field coil goes out... again.
A field coil is a rather robust part that one expects to last years, though I realize it is entirely within the realm of possibility that this new Genuine Honda part was faulty. There aren't any relevant TSB's that I can find, so I post my query here for those with possible insight.
Is i possible that, somehow, the field coil was stressed by the either of the two incidents that happened over its lifespan?
BobBeird
Honda CR-V & Element
May 15, 2015 12:22 AM
tashascivic
Honda Civic (2006 - 2015)
Jul 11, 2013 09:52 PM
boffin1946
Jul 1, 2013 11:31 AM
fragmare
Jul 19, 2012 02:13 PM
picthis1
11
Sep 3, 2011 09:06 PM
