AC Problems on my 2000 Civic
2000 Civic Coupe
Did a whole ac swap after ac went out
New Compressor
New Condenser
New AC Drier
New Expansion Valve
New Evaporator Core
Tested the Ac this morning condensor fan won't turn on AC doesn't blow cold air only the fan.
Fuses look fine so not too sure what to do right now.
Seems like theres no power going to the compressor or condenser not sure what to do.
Any help will be appreciated thank you.
New Compressor
New Condenser
New AC Drier
New Expansion Valve
New Evaporator Core
Go back through your installation. You have either left something unplugged when you removed the dash/blend box OR you do not have the proper amount of refrigerant in the system. If you use a paper clip (bent into a "U" shape) and jump the two wires in the pressure switch sensor on top of the dryer... the compressor should engage if everything else is proper (this will tell you if you have the incorrect amount of refrigerant).
