Intake Manifold Gasket Question: Is my replacement is missing the red square gasket?
Hi all,
I am replacing the intake manifold gasket on my 1995 Del Sol S with a D15B7. The replacement gasket I got at the store doesn't include the small rectangular gasket on the interior. I see other images online that do contain it. Do I need to buy it separately? If so what is the part#? If my replacement is missing it I will return it and find another.
Thanks for any help. I can't see any part number listed for it.
Re: Intake Manifold Gasket Question: Is my replacement is missing the red square gask
Without a photo (or a link to an image that you have seen), I am not sure what you are referring to. The intake manifold gasket is ONE piece. You may be talking about the throttle body gasket as a separate piece, but this part is not necessary to replace the intake manifold gasket.
Here's an image. The manifold gasket I received from NAPA is all metal, no red square-ish rubber gasket. Some gasket images I see online have it, some don't.
