MFactory gear sets on d series
I'm in the middle of replacing my input shaft bearing on my NA 95 civic ex that i plan to turbo one day to like 300hp max nothing crazy and id like to keep it a fun daily driver. I have an MFactory LSD and carbon synchros to install as well.
then i saw these other gear set options on MFactory for the d-series:
1.565 3rd gear
1.320 4th gear
1.00 5th gear
4.5, 4.7 or 4.9 final drive
my current gear ratios are:
EX
1st-----3.250
2nd-----1.900
3rd-----1.250
4th-----0.909
5th-----0.702
FD-----4.250
QUESTION is, knowing that i want to do light turbo daily driver this car, would i get any extra fun while not destroying gas mileage or daily drivability by getting those MFactory gear sets or a certain combination of them to replace my stock gear sets?
1.565 3rd gear
1.320 4th gear
1.00 5th gear
EX
1st-----3.250
2nd-----1.900
3rd-----1.250
4th-----0.909
5th-----0.702
FD-----4.250
The shorter (bigger number) your gear ratios are, the faster the car will accelerate. Even with your current final drive ratio (4.25:1), the new gear set will turn 30% higher engine RPM at any given highway speed, and if you add a shorter final drive (bigger number) with it, the engine speeds at highway speeds will be even higher. This will affect fuel economy. At 300 wheel HP... I would just install the LSD and synchros.
