ECU Lights
Old Feb 10, 2025 | 08:44 PM
@Jooste's Avatar
Default ECU Lights
Hello
I have a Honda 1989 model and on the ecu it has a small clear panel with numbers 8,4,2,1 on it with a red light behind each one.
When car is started numbers 4 and 2 are on
What does that mean ?
Regards
Old Feb 10, 2025 | 09:17 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: ECU Lights
It means that you have a Code 2 and a Code 4. I am not sure what the 2 is, but the 4 is a Crank Position Sensor failure. You need to find a FSM for the model vehicle/engine that you have and the codes will be listed in the "Fuel" section.
Old Feb 10, 2025 | 10:35 PM
@Jooste's Avatar
What is the FSM ?
Old Feb 11, 2025 | 05:45 AM
7rrivera7's Avatar
I'm pretty sure that's a binary counter and if it's only showing 4 and 2 lit, and this doesn't change, it's code 6 - ECT (engine coolant temp). Either the sensor is bad, disconnected or the wiring is open.
Old Feb 11, 2025 | 09:03 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Originally Posted by @Jooste
What is the FSM ?
Factory Service Manual.
Old Feb 12, 2025 | 09:25 PM
@Jooste's Avatar
I did change the coolant temp sensor and did measure 5 volts on the plug.
it seems the car does not overfuel anymore and starts easier.But the lights on ecu are still on,can i clear or reset it somehow ?
Old Feb 13, 2025 | 08:32 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Disconnect the battery (or unplug the ECU... all three plugs) for 30 minutes, reconnect and see if the lights come back on.
jdm_vtec
Nov 15, 2006 01:37 PM
EF4lyfe
Feb 3, 2004 04:39 PM
JSPECHB
Oct 24, 2003 11:02 AM
86CRXSi
11
Jun 6, 2002 06:18 PM
