feedback on ACT streetdisc clutch and Xtreme Pressure Plate
clutchmaster had a booth at sema and was suggesting that their cluthes were better and ACT clutches caused crank walk on prelude motors.. well i've had the same act clutch and pressure plate.. through my h22a.. crank walked about 3 inches after i was done with it.. and now my h23a block is feeling the same.. i can feel a grinding in the clutch pedal.. but it still runs.. i think the pressure plate is just too rough for the motor and its destroying it.. anyone else had the same problems? i'm sending my pressure plate back to ACT to get tested.. they never heard of the problem
I have the ceramic race one in my car and it's held up to the season of harsh launches and power shifts.. So far no complaints except under the very last day of test when it started slipping.
Actually it's not difficult launching with a street disc. Once you get used to the pedal pressure, it's no different than OEM clutches.
y do you feel you need such a stiff preassure plate
i bet the heavy duty one is fine and will be better for draggin on a regular lude
its hard to slip a xtreme plate
my friend has 1 and he wishes he got a heavy duty cuz its hard for him to slip it now
Heavy duty holds something like 276 torque and xtreme 386 torque. 276 is too close for comfort for me once I sleeve the block. And I have no problems feathering the clutch at all. Absolutely no harsh engagement. Your friend have a 5th gen? It's an ha3-xtss kit right?
Guest
Posts: n/a
i have the hdr6 in my prelude and i like it.... i have driven a xtss in a 00civic si and it felt nice, easy enough to slip nad grabed like hell.... i think im gona go with the xtr6 when i do my swap
i'd rather a pressure plate and clutch to be more of an on/off setup..
i see no problems in this clutch/pressure plate aside from it destroying motors.. and on my next motor i'll seek a different clutch/pressure plate assembly.. might just be a defective pressure plate.. i'm not sure
SuicideSlide
11
Aug 29, 2004 01:25 PM
