Eg6 sunroof-moonroof
Old Feb 4, 2025 | 12:48 AM
Giorgos_Eg6's Avatar
Default Eg6 sunroof-moonroof
Hello guys. I have a 92 eg6 uk model with metalic sunroof . I need to replace my sunroof and i can only find glass sunroof from sedan 4dr . The dimensions are the same but the way they connect on the mechanism are diferentt .On 2dr sunroof there are metal brackets and you screw the bolts sideways. on the 4dr sunroof the " bolts "are attached on the sunroof frame and you screw nuts on them. Did anyone made this replacement to give me some guidelines. On 4dr the sunroof slides in the roof. on 2dr it opens over the roof. Also i learned tha there was glass sunroofs on 2dr eg's but there were produced only for jdm market. Thanks and sory for my english
Old Oct 10, 2025 | 05:41 PM
JoeEG9's Avatar
Default Re: Eg6 sunroof-moonroof
Hi Where you able to fit yours? Just wanted to try Eg6 sunroof glass to my EG9
Old Oct 15, 2025 | 06:12 AM
No i was lucky enough to find a 2door glass sunroof to replace mine. to make the replacement of a 2 door with 4 door i believe you must replace the mechanism too
ludeking1007
Aug 16, 2009 05:48 AM
davelarue
Jun 13, 2008 03:21 AM
Sephro
May 9, 2003 04:58 AM
speed_racer012
Feb 26, 2003 06:18 AM
