1993 eg sedan manual steering rack
Old Feb 1, 2025 | 07:14 PM
ChinoEGsedan's Avatar
Default 1993 eg sedan manual steering rack
Old Feb 1, 2025 | 07:18 PM
Default Re: 1993 eg sedan manual steering rack
Having a problem where the passenger side of the manual steering rack is not lining up with the bolts is there any modification I have to do or did I just get sent the wrong part from parts geek. This is a ps car but was already swap to manual but kinda janky.picture below is old steering rack
Old Feb 1, 2025 | 08:35 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It appears that you have a P/S K-member... the passenger side mounting point is different than one found in an actual manual steering racked car. You will either find an actual manual EG K-member and swap that in with your new rack... or if you want an easier solution, get a bracket from NRG Tech. Here is a link below:
https://www.nrgtechonline.com/produc...g-rack-bracket
Rtboy10
Jun 16, 2011 04:20 AM
95blackEG
Oct 17, 2008 02:10 PM
