Honda CR-V & Element 2WD & 4WD Element & CR-V
06 CR-V Crank no start
Old Jan 30, 2025 | 04:20 PM
Chaneriel's Avatar
Default 06 CR-V Crank no start
I have an 06 CR-V that I parked one night after work in 40 degrees. Next day i had work off, and the morning after that I went to start and it crank, crank, crank, but never started, and thats where its been for 2 more weeks. I have compression, and starting fluid doesnt work which rules out fuel, and its also above freezing now. In-line spark plug tester says that there IS power going FROM the coil TO the plug, but I took a plug out, connected one end of a jumper cable to the battery ground and the other end to the plug, and even used a power probe hooked up to the battery positive and then touched the negative clip to the spark plug thread and it got power meaning that the spark plug should be properly grounded, but the spark plug itself isnt producing spark. I know its not battery because its a new battery and also I tested it while jumping the car off another car. My ignition coil fuse in the secondary fuse box looks fine, as well as the 50a ignition relay in the primary fuse box under the hood. I have tried this with my old spark plugs which were fine when i took them out, i just figured I would replace them since I was doing a valve adjustment, AND with my new plugs which were also working fine until the day i parked it
Old Feb 1, 2025 | 12:26 PM
Chaneriel's Avatar
Default Re: 06 CR-V Crank no start
Ok UPDATE: The spark plugs ARE sparking. So I have spark and compression, and starting fluid didnt work
civic2sick
Feb 26, 2020 09:39 PM
Colin Adams
Honda Civic (2006 - 2015)
Sep 28, 2013 02:41 AM
civic92si
Mar 29, 2007 08:28 PM
Beau Gotti
May 6, 2006 06:45 PM
under_construction_88_crx
Mar 3, 2005 02:57 AM
