Honda CR-V & Element 2WD & 4WD Element & CR-V
06' CR-V Tire Switch with 04' Cr-V
Old Jan 26, 2025 | 03:03 PM
Midwest_CRU's Avatar
Default 06' CR-V Tire Switch with 04' Cr-V
Currently undergoing a bit of a project and trying to figure out what the best move is so I thought I would come to the source for some information.
I wrecked my 2004 Honda CR-V and went out and found a 2006 that I replaced it with, the front end of the 04 was smashed in but the tires and rims are in great shape and I have less than a year on the A/T tires that I put on there. The issue that I am facing is that the 2004 Rims that I have are 15 inch while the 2006 has 16 inch rims. I attempted the switch just to see what would happen since its the same bolt pattern and in theory I felt like it would work, the issue though is that the break caliper is rubbing on the front tires (have not tried the rear) and not letting it move freely. I would rather not have to get rid of the new tires If I can help it but am running into a brick wall here trying to figure out what I can do to make this work. Any advice? Any other 15 inch rims from any other car that could possibly clear the caliper? I also have access to the whole CR-V so if there a way to switch some parts out to make it work I would be open to those suggestions as well, thanks in advance.
Steven.
Nov 8, 2006 02:20 AM
autoEk
Sep 30, 2006 10:25 PM
94gsr18kid
Feb 14, 2005 03:16 PM
2005 TSX
Jan 6, 2005 11:48 PM
