Did I check my camber correctly? PLEASE HELP
Old Jan 23, 2025 | 02:17 PM
Rfishi's Avatar
Default Did I check my camber correctly? PLEASE HELP
  1. Run a straight piece of metal along the length of the car with a bubble level in the center
  2. Add spacers underneath passenger side tire until the bubble level showed level
  3. Put a bubble level along the wheel to check camber
    Driver side after wreck
    Passenger side after wreck
I only added spacers to the passenger side since my driveway is slanting down that direction. I did not check if the rear tires were level, and did not add any spacers to the back tires. IS THIS A PROBLEM? I didn't think I needed to level the rear tires since I'm only checking camber on the front tires, am I wrong? Did I do this correctly?
Old Jan 23, 2025 | 03:27 PM
spAdam's Avatar
Loved
Community Favorite
Default Re: Did I check my camber correctly? PLEASE HELP
The only problem is that you’re not necessarily looking for zero. You need to get a number.
good job leveling your floor though.
Old Jan 23, 2025 | 04:36 PM
Rfishi's Avatar
If the camber is too negative from the front end collision, should I replace the upper control arms? If so should I look for adjustable ones? What other components should I check for damage/replace?
Old Jan 26, 2025 | 05:42 AM
spAdam's Avatar
Loved
Community Favorite
Uppers are the least likely to bend.
Look at lower arms, subframe, knuckles/uprights first. If the uppers ARE bent, most likely something else is too.
Old Jan 26, 2025 | 05:47 AM
Rfishi's Avatar
When I look, I don't see any obvious damage or bends on any of the parts, but camber is at like negative 8 so I know something had to get bent, but I don't know what.
If something is bent causing negative camber, could I just get a camber kit instead of replacing a million things before finding out what's actually bent?
How can I tell if my lower arm is damaged? The bushing on the lower arm where the fork connects to looks worn down but it always has. Do you think it could also be the tie rods?
Any parts I'm gonna need I need to order by today, so any help is greatly appreciated. I don't want to end up spending a lot of money on parts that don't fix my problem.
Old Jan 26, 2025 | 06:03 AM
spAdam's Avatar
Loved
Community Favorite
How is the ride height from side to side? Measure from wheel centers to fender lip. Check the knuckles closely. How much camber are we talking? What’s the split? How’s the caster? What was the nature of the front end damage you mentioned? Negative camber is kind of a tough one to acquire in the usual front end hit, unless you’ve shifted the whole subframe over to one side or bent a knuckle.
Old Jan 26, 2025 | 06:20 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
I was wondering what he was doing with that.
Old Jan 26, 2025 | 09:06 AM
Rfishi's Avatar
I know this is a lot to look at, but I really appreciate the help. I tried to answer your questions as well as I could. Hopefully I can make a plan of what parts to order by the end of today.
RIDE HEIGHT: is about 13.25 inches on both sides (which is weird because yesterday it was 14 on driver side and 14.5 on passenger. I drove a very short distance since then).
CAMBER: I don't have a camber gauge to check exact camber but here is my readings from my bubble level:
CASTER
: I don't think I have the tools to check caster, and I don't really understand how to.
THE ACCIDENT: I was driving 30-35mph and a SUV ran a stop sign in front of me. I tried to swerve left around them, but they kept accelerating, so I slammed my breaks and all 4 tires started sliding, and I hit into their rear door. Hard to say the speed, but stuff in my backseat was thrown into the front. It looks like my passenger side took most of the impact, because the bumper was dented on the passenger side and slightly disconnected on the driver side. The inner tie rod was leaking steering fluid on the passenger side. Here is the bumper damage:
I've driven the car since the wreck and it just feels funny. The steering wheel wants to pull to the left and I just feel overall less control. It just feels way less smooth too.
ADDITIONAL PHOTOS THAT MAY OR MAY NOT HELP YOU SEE WHAT'S GOING ON:
I grinded some of the knuckle off a long time ago to install a lug stud, thats not from the wreck
If the subframe is bent, do I just need to replace it with a new one? How big of a job is that?
Old Jan 26, 2025 | 11:18 AM
Rfishi's Avatar
Okay, I found damage. The motor mount on the left side is completely destroyed. It's bent at almost a 45° angle and the rubber is destroyed.
Since the motor mount is bolted to the subframe, I'm assuming that the subframe is definitely bent. What do you think? ​​​​​​
EDIT: Maybe I'm confusing the crossmember And the subframe. All this terminology is new to me.
Old Jan 27, 2025 | 06:21 AM
spAdam's Avatar
Loved
Community Favorite
Crossmember/subframe are find of interchangeable, but usually around here the crossmember is in front and ties the frame rails together and the subframe is behind the drivetrain locating the control arms and steering rack.
Looks like you might have picked up some frame damage on the right front corner, the frame horn appears to have a twist and the lower core support has a taken a whack in and under.
Also your lower arm bushings are in really bad condition and this is doing nothing to help your alignment or the repeatability of your measurements.
Get yourself $30 magnetic digital level and magnet or tape it onto your current level.
Old Jan 27, 2025 | 01:04 PM
Rfishi's Avatar
So would you say a new front crossmember is required?
Old Jan 27, 2025 | 06:27 PM
spAdam's Avatar
Loved
Community Favorite
How married to this car are you?
Old Jan 29, 2025 | 04:37 AM
Rfishi's Avatar
There is a sentimental attachment to the car, yes, but that's not my inspiration to fix it.
As I see it, a used crossmember/subframe will be much cheaper than buying a whole other car. And I would never be able to afford another car, let alone one as reliable as this one.
I just want to make sure that those parts will indeed fix the car back to its former condition before I spend the money.
Old Jan 29, 2025 | 06:49 AM
spAdam's Avatar
Loved
Community Favorite
Okay. If you're willing to do the work I'd suggest that you find a body shop with a frame machine and pay them a couple hours labor to measure it out and diagnose what's bent. From what I see in those pictures I think your right frame horn is bent inward.
Old Jan 29, 2025 | 11:18 AM
Rfishi's Avatar
I'm having trouble finding what the "frame horn" is. Can you share a picture of what it is? Is it a replaceable part? When in search frame horn, the only parts that show up are the actual horn 🎺.
I've done loads of work on this car, but all of this stuff is brand new to me, so sorry if some of my questions sound silly.
Old Jan 30, 2025 | 10:48 AM
Rfishi's Avatar
I've found a '92 Civic LX at a salvage yard, but parts from that won't fit on my '90 will they?
What years Integra would work?
Old Jan 30, 2025 | 05:35 PM
spAdam's Avatar
Loved
Community Favorite
No, not even close. What I'm referring to as the 'horn' is basically the whole frame rail that comes forward from the firewall/bulkhead to the front core support. Yours looks like it is bent. No number of bolt on parts will fix that, and your bodywork most likely wont fit right either.
Old Jan 31, 2025 | 03:58 AM
Rfishi's Avatar
Is what I circled in the picture what you are referring to as the frame rail/horn?
CHAMPwhteEK
Suspension & Brakes
Jul 7, 2009 03:22 PM
accord64
Sep 9, 2007 10:12 AM
VtecFreePrelude
Sep 29, 2006 08:21 AM
tthomass
May 31, 2006 02:50 PM
Eg6_JDM
Oct 1, 2002 08:52 PM
