1994-1995 Del Sol SRS Retrofit Kit - SB 09-006
I made a post HERE a bit ago about my SRS light being on and none of the standard methods worked for troubleshooting and no one here seemed to be able to have any help.
I finally took it to a dealer, and they said this is a known issue on 1994-1995 Del Sol vehicles and there's actually a service bulletin for the issue. The resolution is to install a new SRS module (different part #) and a new wiring harness as well, called the SRS Retrofit Kit.
I think I'm going to do the work myself, as dealer wanted $1600 parts + $2200 in labor for the job.
I'm hoping a MOD can reach out to me. I'd like to attach the PDF of the SB to this so that others can also use the information, but maybe I don't have the right permissions. It says PDF is allowed as an extension type for attachments, but when I try to attach it says "This AI image has the incorrect file extension." It's neither an image nor anything to do with AI so IDK what it's talking about.
AzntaggeR
14
Dec 26, 2002 02:53 PM
