FS or trade:fully built turbo motorswap
Old Nov 19, 2002 | 10:31 AM
paulzy's Avatar
Default FS or trade:fully built turbo motorswap
https://honda-tech.com/zerothread?id=337925
Old Nov 19, 2002 | 10:48 AM
paulzy's Avatar
Default Re: FS or trade:fully built turbo motorswap (paul_vang)
here's the lowdown if nobody wants to clikc onthe link....
I'm running out of money to finish my turbo motor, so I will trade with a fully built and balanced high compression NA swap
[ One very major reason is because I just lost my JOb /B]
my motor:
stock 99 Si head
GSR cams with skunk2 gears(red)
b18b1 block
RE blockguard
GSR oil pump with Pro drive gears
new factory GSR water pump
New GSR timing belt
stock b18b1 oil pan
Je 9.0:1 pistons
eagle rods
ACL bearings
fully balanced
stock headgasket
ARP headstuds
full-race SS turbo manifold(flanged for a t3)
(fully rebuilt)cable LS tranny with Quaife differential
DSS stage 3 axles with hubs
paxton fuel pump
turboXS Type H bypass valve
HKS 40mm wastegate
Hasport cable to hydro conversion
hondata 4b with programmer and emulator(with P28 Reworked for hondata)
autometer boostgauge
brand new CM stage 4 cluthc kit with new TO bearing
ITR flywheel with 10K miles and new pilot bearing
custom intake manifold
PWR radiator
what you have right here is a stout motor ready for high boost and great power numbers...all you really need is an IC, turbo, piping....
There is more stuff, but this is all I can think of as of right now.
Motor is fully assembled with all hardware and torqued down. ready to bolt tranny up and drop in. Everything here has 0(zero)miles on it.
will trade for a fresh high compression motor with tranny(LSD)...I'm giving you pretty much the full swap, so I will likely want the same. I don't want some halfassed motor with CTR or ITR pistons. I want something that can throw down power...
or I will sell teh whole setup for $6500/obo What you are getting here is worth way more than that with no miles at all
[Modified by paul_vang, 7:15 PM 11/19/2002]
Old Nov 19, 2002 | 10:54 AM
paulzy's Avatar
willing to do financing with trusted people only
Here's some more stuff...
72lbs MSD injectors
moified GSR fuel rail
B16 TB
GSR wiring harness
all sensors
[Modified by paul_vang, 11:59 AM 11/19/2002]
Old Nov 19, 2002 | 11:13 AM
InfamousRS's Avatar
It looks like you are so close...its a shame your giving the motor up...
Old Nov 19, 2002 | 11:22 AM
AB16A2T's Avatar
Default Re: FS or trade:fully built turbo motorswap (InfamousRS)
Dude you lost your job.. that sucks... Good luck selling your motor.
Old Nov 19, 2002 | 11:42 AM
ecoli's Avatar
good luck........
Old Nov 19, 2002 | 11:47 AM
paulzy's Avatar
Default Re: FS or trade:fully built turbo motorswap (ecoli)
UPDATE: also have an MSD SCI-L with blaster SS coil...modified LS distributor also
_______
tahnks guys
Old Nov 19, 2002 | 01:03 PM
G2turbo_terror's Avatar
Old Nov 19, 2002 | 03:13 PM
gritsak's Avatar
where are you located?
Old Nov 19, 2002 | 04:48 PM
paulzy's Avatar
Default Re: FS or trade:fully built turbo motorswap (gritsak)
twin cities, MN
Update: my wife and I decided(her mostly, lolz)that I should sell instead of a trade. So it's for sale now
[Modified by paul_vang, 5:49 PM 11/19/2002]
Old Nov 19, 2002 | 05:51 PM
falcongsr's Avatar
What is this crap?
god what a killer setup!!!!
i have a bone stock 94 auto hatch looking for something like this...hmmmmmm
Old Nov 19, 2002 | 07:14 PM
gritsak's Avatar
who did all the work on the motor? and also, i know since your not a shop a warranty is gonna be pretty much on trust only... but with respect to whoever built the motor, what happens if whoever buys the motor goes to start it and something is wrong? the buyer kinda takes a big risk trusting the work of whoever built it, so with that said is there any kind of "warranty" that you can offer to the buyer?
thanx
Old Nov 19, 2002 | 08:04 PM
paulzy's Avatar
I built it...well, I can rebuild it if anything happens. well, there are a lot of variables here though.
like good break-in and such...I'll go into more detail later. I have to go pu tmy kid to sleep
Old Nov 19, 2002 | 08:31 PM
SiRkid's Avatar
nooo, dont sell
Old Nov 19, 2002 | 10:54 PM
*Boostwerks*'s Avatar
Free bump for the late nighters....
Good luck man
Old Nov 19, 2002 | 10:59 PM
Blown90hatcH's Avatar
I will vouch for Paul anytime. Bump for a great guy in a tough situation.
Old Nov 20, 2002 | 06:47 AM
paulzy's Avatar
Default Re: FS or trade:fully built turbo motorswap (Blown90hatcH)
thanks guys
GSRTurbo916
Apr 18, 2016 11:47 AM
Black DC2
Jun 7, 2007 03:34 PM
jdm4show
Sep 4, 2004 12:40 AM
paulzy
Dec 27, 2002 01:18 PM
paulzy
Nov 20, 2002 01:53 PM
