b16a overheat when idling
Old Jan 13, 2025 | 11:48 AM
JUNYATSU's Avatar
Default b16a overheat when idling
Hey guys I'm back again like the title says when my car idles the temp starts rising the first time this happen I completely flushed the coolant and refilled and bled the system. Now its doing it again I was advised to get a new thermostat the car isn't smoking so i don't think its my head gasket i also notice when i hit the gas when it idles the temps drop down. my rad fan does turn on so its not off another thing is when i would let it warm up it gauge doesn't get to middle half it usually sits around 1/4th up. but that's the least of my issues. i also wanna know some google searches say the 99-00 b16a2 si thermostat doesn't fit but the 95 del sol b16a3 fits the JDM b16a
any help is appreciated thank you
Old Jan 14, 2025 | 03:27 AM
theYBLEGAL's Avatar
Loved
Default Re: b16a overheat when idling
Are you pushing coolant? Overflow filling up? Having to refill radiator at all?
Old Jan 14, 2025 | 02:13 PM
JUNYATSU's Avatar
Never had my overflow fill but I've seen my radiator leak coolant i believe there is a small crack at the bottom near the plug for right now I ordered a new thermostat because my bottom radiator hose is much cooler than my upper hose
schock3
Jul 13, 2010 09:02 AM
si 1
Sep 24, 2006 01:51 PM
si 1
Sep 24, 2006 08:25 AM
