what is this pulley for?
Old Jan 13, 2025 | 06:13 AM
accelelag's Avatar
Default what is this pulley for?
PS belt slipped off last night, and it slipped onto this pulley. The red mark in the picture is where the pulley was. Right now the car drives perfectly fine (other than no power steering). My question is, is this pulley necessary, or can I put my belt back on and be fine?
Old Jan 13, 2025 | 07:59 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: what is this pulley for?
It looks like the A/C tensioner idler pulley... although the middle of the bearing is missing. It is not needed for P/S, however, you WILL have to replace it (and any other missing parts for the A/C tensioner assembly) if you want to get A/C working again.
Old Jan 13, 2025 | 08:17 PM
accelelag's Avatar
Haha you're absolutely right. I knew it looked like the AC pulley, but when I went to check it at first, I saw the nut was still in place assuming that the pulley was still attached to the nut.....
How in the world did it fall out if the nut is still tight on the bracket??? LOL
Thanks for your response! I'll get the pulley back on tomorrow morning (assuming the bearings are still also attached behind the nut)
Old Jan 14, 2025 | 07:49 PM
JRCivic1's Avatar
10 Year Member
Community Builder
You need another pulley... that one FAILED. The bearings are gone and all that will still be bolted to the bracket is the inner race. Fortunately for you, all of the hardware is still present, so get a new pulley and put it back together.
Old Jan 14, 2025 | 08:08 PM
accelelag's Avatar
Yes sir!
Checked it out this morning and instantly ordered an OEM pulley & bearings. I'm very lucky that it only took my PS belt off, and that I even managed to recover the PS belt itself.
Thanks for your time!
tachophobia
May 28, 2009 12:47 PM
JDM H22
Honda S2000
Nov 20, 2008 07:18 AM
infamouskillas
Mar 10, 2008 11:27 PM
ktwanky
Jan 19, 2007 09:51 PM
