Honda CR-V & Element 2WD & 4WD Element & CR-V
1999 crv crank sensor test?
Old Jan 12, 2025 | 10:57 AM
anarky321's Avatar
Default 1999 crv crank sensor test?
are you supposed to be able to see crank sensor reading in a high end scan tool for a B20 ? what should the reading be during cranking? id just like to verify the suspicion its the sensor before tearing off the belt cover
Old Jan 14, 2025 | 03:49 AM
theYBLEGAL's Avatar
Loved
Default Re: 1999 crv crank sensor test?
The TDC the ecu looks at for starting is in the distributor.
The crank sensor by the crank is the crankshaft fluctuation sensor. Mostly for emissions to my knowledge, and doesn't keep from starting.
Idk about on a scan tool. Oscilloscope on the sensor is probably the way.
Hope that helps.
Old Jan 14, 2025 | 04:35 AM
anarky321's Avatar
so basically my distributor crank sensor can be messed up and i'd still get spark at the plugs ?
Old Jan 14, 2025 | 06:32 AM
theYBLEGAL's Avatar
Loved
No.
Basically the crank fluctiation sensor at the crank can be messed up but you should still get spark if the distributor TDC is working correctly.
TDC is top dead center. There is a sensor in the distributor for this, and the ECU reads it only durring cranking to know when to fire spark.
Natie Barnard
Jan 16, 2019 06:38 AM
will/i/am
Jan 22, 2018 07:57 AM
pokmijn
Jan 7, 2008 05:47 AM
