Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
02-04 Civic SI hatchback: starter
Old Jan 11, 2025 | 01:09 PM
Philip54's Avatar
Default 02-04 Civic SI hatchback: starter
How do I access the starter and engine solenoid, which are apparently located under the intake manifold? What parts need to be removed?
Thanks
Old Jan 11, 2025 | 08:17 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 02-04 Civic SI hatchback: starter
Remove the intake manifold, fuel feed line, intake air tube, and brake booster and evap hoses. Lay a towel over the valve cover and lay the intake manifold up on the towel (with the throttle cables still connected). You will have free access to the starter for easy removal. Make sure the battery is disconnected... and be careful around the knock sensor, it is fragile.
Old Jan 12, 2025 | 02:24 AM
Philip54's Avatar
Many thanks for your help. I like your fleet!
Old Jan 12, 2025 | 08:34 PM
JRCivic1's Avatar
10 Year Member
Community Builder
I do too !!! LOL I have a couple more that aren't listed that will be project threads here before you know it.
alowe336
Apr 3, 2017 08:39 PM
nopain20
Honda Civic (2006 - 2015)
Nov 7, 2014 09:32 PM
sicivic
Jan 28, 2008 04:42 AM
sicivic
Dec 11, 2007 10:44 AM
sloop
Nov 29, 2002 08:14 AM
