Wheel Sizing and Offset?
I recently found a set of wheels I think would look good. But I have NO IDEA what sizing will fit the car.
The wheels are a set of Work Equip 01s.
They are 14x5.5j, with an offset of +35.
The car is pretty much stock.
Will these fit? Or am I about to make a huge mistake?
I mean, the stock size for an EJ1/EX is 14x5.5 +45. They’ll fit fine, just a little further outboard than stock. Will they look good? Sure, probably better than the stock wheels.
Typical “modern” aftermarket sizing for these cars is 15” or 16” x 7”-8” width in +45 to +32 offset. You need to start lowering your offset once you get wider than 7” in order to clear the suspension on the inside of the wheel. 8” +32 is about as much as will fit under the fenders and not poke out and look silly.
