1996 Civic No Spark troubleshooting details in post
Old Jan 9, 2025 | 12:48 PM
beanburrito46's Avatar
Icon5 1996 Civic No Spark troubleshooting details in post
I have a 1996 that I just did an engine swap on after blowing up my y7. I've put a Y8 in and it has no spark.
I have:
1. tried the Y8 ECU I got with the engine
2. tried the y7 ECU from the car that was running before the swap
3. Tries the old distributor from the Y7
4. Tried an new distributor TEC type (as defined by the OEM service manual)
5. Done the ICM input test (results below)
- step 1 - Remove the distributor cap and leak cover - DONE
- step 2 - Disconnect the wires from the ICM - DONE
- step 3 - Turn on ignition and check voltage at BLK/YEL = 12.3 VDC <--- correct
- step 4 - Turn on ignition and check voltage at WHT/BLU = 12.1 VDC <--- Close
- step 5 - Disconnect ECM?PCM Conector A and check continuity on YEL/GRN between ECM and ICU - 0.1 OHMs <--- Correct
- step 6 - Check continuity between YEL/GRN and ground = OL (no continuity) <--- Correct
- step 7 - Check continuity between BLU wire between ICM and Tachometer test connector = 0.5 OHMs <--- Correct
- step 8 - Check continuity between BLU and Ground
------- With ICM wires disconnected still = OL (no continuity) <--- Correct
------- With ICM wires connected = 1.1 OHMs <----- No idea if thats normal
I also swapped the Crank Position sensor with a known good but still no spark.
all the spark plug wires have the correct resistance
I'm out of ideas. in theory all the parts should be good. I guess it's possible the new distributor is bad but that seems unlikely.
Side notes on other stuff that's not yet hooked up:
O2 sensors
Oil Pressure sensor
Knock Sensor
Temp Sensor
But, to my knowlege none of these should prevent spark. Please let me know if you have any experience with this or ideas.
Old Jan 9, 2025 | 08:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 1996 Civic No Spark troubleshooting details in post
Do you hear the fuel pump prime when the key is turned on ?
Old Jan 10, 2025 | 02:35 PM
fuel pump works and compression is there the only problem is spark
Old Jan 30, 2025 | 03:23 AM
any help would be greatly appreciated am thinking about just selling the car at this point
Old Jan 30, 2025 | 07:05 AM
Lock914's Avatar
How about the spark plugs themselves i bought a set car wouldn't turn over put old ones back in and started right back up.
Old Jan 30, 2025 | 07:30 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Bad coil or ICM. You could try swapping in a "Known Good" distributor and see if the engine starts.
Old Feb 23, 2025 | 12:05 PM
i bought new plugs nothing still imma take the wiring harness out and check it and fix any solders and or wires and get a new distributor
Ep1dem1c
Feb 14, 2021 06:03 PM
Jomtapia
Jul 14, 2019 07:04 PM
Noo_Ish_mee
Jun 27, 2016 02:44 PM
HondaMizzan
Aug 1, 2015 03:13 PM
oliebollen
Feb 17, 2014 09:34 PM
