Intake on 94 civic coupe swapped with D16Y8
Old Jan 7, 2025 | 03:51 PM
luckyej2's Avatar
Default Intake on 94 civic coupe swapped with D16Y8
Hello!
I recently bought a 1994 Honda civic coupe, with a swapped D16Y8 and the airbox had a hole in it. I ordered a new intake but I’m not sure if I got the right one. I got the DC sports 92-95, part number SRI5516. I realized after I ordered it, that the engine was from the 96-00 models.
My question is since there is an intake air temp sensor, would I need an intake that would allow the sensor to be used, or could I use the one I bought?
Thanks!
edit: I figured it out. Sorry for posting
Old Jan 7, 2025 | 08:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Intake on 94 civic coupe swapped with D16Y8
You bought the correct intake kit... since your IAT sensor is mounted in the intake manifold, you do NOT need a hole (and rubber grommet) in the intake pipe to install the IAT sensor.
Old Jan 8, 2025 | 04:30 AM
Chrisfrom1986's Avatar
@JRCivic1 where does the iat sensor go on the y8 manifold?
Old Jan 8, 2025 | 06:31 AM
luckyej2's Avatar
This is a picture of my engine bay! On my intake I see there is a sensor and this is why I’m wondering if I ordered the wrong part?
This is a picture of my engine bay! On my intake I see there is a sensor and this is why I’m wondering if I ordered the wrong part. I would need an intake that has a hole(and rubber grommet) that would allow me to install the IAT sensor, correct? Or would I be able to use the one I already purchased?
I appreciate the help!
Old Jan 8, 2025 | 07:37 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Chrisfrom1986, I apologize... apparently I didn't read the OP's original post close enough. The Y8 Intake manifold does NOT have a provision for the IAT sensor to be bolted on, therefore, you WILL need to drill a hole into your AEM intake tube (and source an appropriately sized grommet) and convert the OE IAT plug into a '96-00 style plug. You will also need a '96-00 IAT sensor obviously.
You COULD purchase the '96-00 DC Sports Intake and the hole and grommet would come with it... but you still need a sensor and will have to modify the wiring on the engine harness to make it work.
lassoguy
Aug 26, 2013 04:12 AM
mycvc8u2
Jul 5, 2003 10:48 PM
X2BOARD
Apr 8, 2003 11:17 PM
zCivic
Sep 14, 2002 12:23 AM
