Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
07 civic si clutch problems
Old Jan 1, 2025 | 06:20 PM
Mcajero10's Avatar
Default 07 civic si clutch problems
Hi all I have a 07 civic si. about 2 years ago I had my clutch changed. exedra stage 2 with lightweight flywheel. about 2 months ago I started hearing a grinding noise only when releasing clutch pedal in first gear. now its doing it when in reverse and releasing clutch pedal. also when I'm cursing at a constant speed and I try to speed up car idles but does not go faster then idle drops and car starts speeding up. I have np issues shifting.
Old Jan 2, 2025 | 08:41 AM
shai x boi racer's Avatar
Default Re: 07 civic si clutch problems
Can you elaborate on the grind?
also, 22 months is a big gap to blame it on the replacement. weeks to a couple months makes sense... 22 months??? I'd take it to a mechanic. They've probably dealt with this issue before. plus, they can fill in the gaps of your explanation by test driving themselves.
nitram.h
Transmission & Drivetrain
Mar 10, 2024 10:57 AM
FliiBoii
Feb 3, 2012 07:50 AM
06 Civic CJ
12
Jan 15, 2012 12:34 PM
HA0LEFIED
May 18, 2007 06:48 PM
