My 2000 Honda civic LX ignition fuse, keeps popping
Like the title says the ignition fuse keeps popping. It’s not popping right when I put the key in, but when I put it to on 2. I know there is a short somewhere just no idea where to look first.
Ignition wire harness leading into the under dash fuse box. Sounds like one of the power wire is pinched against metal and grounding out
The power junction plugs under the intake manifold is a common cause of the issue that you are experiencing on '96-00 Civics... I would start there.
stroker393
Jan 21, 2016 03:21 PM
simers
Jan 5, 2016 04:32 PM
