Honda CR-V & Element 2WD & 4WD Element & CR-V
Do all K24 leak oil from pressure sensor?
Old Dec 20, 2024 | 07:38 PM
jstrange's Avatar
Default Do all K24 leak oil from pressure sensor?
Im curious if all the K24 motors eventually leak oil from the oil pressure sensor?
I owned a 2006 CRV SE for over 10 years, did 280k miles on it, that sensor was never touched and then one day I noticed it was leaking, I had the mechanic swap it out and he cracked the bung (block) and I was never able to fix it. I felt like it wasent his fault, that the bung was already cracked and he just made it worse when he screwed in the new sensor. I have read tons of testimonies online of K24 owners with the same issue.
Im thinking about getting another 2006 CRV but Im concerned about the oil pressure sensor mainly, the rear suspension sag and lateral movement on gravel, snow and ice is another one (crazy feeling)
I also owned a 1998 CRV with the B20, I know everything about that car, but its tough to find them in decent shape these days so I was considering another 2nd gen.
Old Jan 2, 2025 | 08:54 AM
Smackin's Avatar
5 Year Member
Loved
Community Favorite
Default Re: Do all K24 leak oil from pressure sensor?
Mines leaked a few times from the pressure sensor during the last decade. Always leaking from somewhere lol. It loves to spring leaks from the spool valve solenoid gasket though. I’d say that’s the most common for the K24.
sethooo
Nov 20, 2021 06:22 PM
07CRV
Sep 30, 2016 04:07 AM
jaysonx
Sep 8, 2003 08:21 PM
Canuk_SiR
Aug 1, 2002 12:16 PM
