Honda CR-V & Element 2WD & 4WD Element & CR-V
Power Window Issues
Old Dec 18, 2024 | 11:01 AM
Stallion68's Avatar
Default Power Window Issues
Hello everyone,
So I have a 2005 CR-V with power window issues. At first the front passenger side did not work from the master switch. But it does work on the passenger door switch. Then a few months later, the front driver's side window stopped working. I put in a new window motor/regulator in the front driver side about 6 months ago, and it worked fine since, so probably not the motor. I read through this entire thread (https://honda-tech.com/forums/honda-...witch-3305987/) but need to know where to go next. I do have power at the green/black wire (2 spot) on master switch harness. I jumped wires as per the link above to make the front passenger window go up and down, but it did not work. I checked all window fuses----all good. I have no issues with the back windows at all just the front.
I also replaced the master switch with a new one from Amazon. Nothing changed. I thought maybe it was b/c it was an aftermarket switch. So I purchased a genuine Honda master switch and still nothing has changed.
Please advise.
Thanks,
Mike
Old Dec 19, 2024 | 03:57 AM
Stallion68's Avatar
Default Re: Power Window Issues
Update: It appears that I do not have power at the green/black wire in master switch harness with key on. Either this was/is an intermittent issue, or I never had power there and may have touched the contact of another wire with my probe while checking that one.
Old Jan 2, 2025 | 03:29 PM
Stallion68's Avatar
Update: I did find two broken wires in the door jamb harness. After repairing them, the passenger side window now works from the master switch. Unfortunately, the driver side still does not work. I do hear a noticeable clicking sound when I move the switch to up or down. I replaced the window motor/regulator assembly in September of this year. The brand was AISIN. Seems to be a respected brand, so I highly doubt that the motor took a crap already. After fixing the broken wires, I swapped out the master switch with another new one that I had........nothing different with the driver's side. Please advise.
mayurji1
Jun 9, 2014 03:49 AM
92-CivicLX
Sep 23, 2013 07:46 AM
mugenpower09
Dec 19, 2008 03:46 PM
VtecCivic93
May 5, 2008 03:47 PM
92ehatch
Mar 3, 2006 02:49 AM
