Low Voltage From MAP sensor, bad luck or wiring?
Old Dec 16, 2024 | 04:34 PM
mistertoo's Avatar
Default Low Voltage From MAP sensor, bad luck or wiring?
Hello all, I'm having a rather silly problem with an OBD1 B18B in my EF sedan. I've had 3 MAP sensors and they all output 0.3-0.6V key on engine off. The car does not start with any of them plugged in, but will run with poor drivability when they are not. I have verified that it's getting 5.0V from the power wire and continuity to the thermostat housing on the ground pin. I've also been able to verify this behavior with a bench power source. Is it possible that I've gotten 3 bad sensors in a row or could there be some other wiring issue at play that I don't know about?
Old Dec 16, 2024 | 10:01 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Low Voltage From MAP sensor, bad luck or wiring?
The original MAP sensor wiring for your EF Sedan is on the firewall... are you still plugged in there ? Have you checked continuity between the signal pin at the MAP sensor plug and the proper location at the ECU plugs ? If you are buying Genuine MAP sensors from your local Honda parts department, three bad brand new MAP sensors is impossible. However, if you are getting them from a local auto parts store, EBay or Amazon... those are all junky or junkier, so all bets are off.
Old Dec 16, 2024 | 10:15 PM
mistertoo's Avatar
using the one on the throttle body thankfully! I've actually been curious if I can just pull that control box off fully now (converted to OBD1 with an aftermarket harness). I do throw a map code when it's unplugged, and although it's a cheap harness I verified as much continuity as possible before install. I can also replicate the behavior independent of the ECU with a bench power supply. Unless there's a way to fry these things by wiring wrong I'll guess an OEM sensor sensor probably fixes my problems
97_ek_coupe
Aug 8, 2013 01:22 PM
TopEndTuner
Engine Management and Tuning
Oct 4, 2008 04:58 PM
ZenDynasty
Dec 17, 2006 11:43 PM
Del Sol on Steroids
Nov 22, 2006 12:50 PM
