question: my crvtec 1/4 mile time
Old Nov 19, 2002 | 09:19 AM
irev210's Avatar
Default question: my crvtec 1/4 mile time
Hey i just bought an 88 CRX HF not too long ago...
im working on crvtec, this process has taken me about a year to get to this point... Im almost ready...
Here are my mods
ITR throttle body, ITR intake manafold, AEM fuel rail, AEM FPR, AEM typeR cai, B&M FPG, ITR flywheel, action 6puck unsprung clutch, YS1 tranny, port/polished head, .5mm oversized molychrome valves, crower 63042A cams, crower dual valvespring, crower titianum retainers, skunk2 cam gears, 2000 JDM B20 (has Z pistons and a knock sensor from the factory) arp head studs, cometic .025 head gasket... i think thats pretty much everything.
what 1/4 mile times do you think ill be able to hit
Old Nov 19, 2002 | 10:45 AM
Urban Business
Guest
Posts: n/a
Default Re: question: my crvtec 1/4 mile time (sirhatchback)
7-10 business days
Old Nov 19, 2002 | 10:46 AM
Rob!'s Avatar
sounds like a lot...take it to the track when ur done then tell us...
Old Nov 19, 2002 | 11:24 AM
keithv's Avatar
Default Re: question: my crvtec 1/4 mile time (RaceFacer)
13s if you can drive.
Old Nov 19, 2002 | 01:12 PM
Jeff C's Avatar
You will have serious traction issues...trust me. Don't expect anything too great until you get used to it.
For example, I ran a 10.1 @ 74 in the 1/8th spinning all the way through the traps w/o nitrous, and obviously on street tires.
Before you put in, GET AN LSD!!!!
Old Nov 19, 2002 | 01:21 PM
Urban Business
Guest
Posts: n/a
Default Re: question: my crvtec 1/4 mile time (Jeff C)
no you didnt
those times are bassackwards
that low of an et would indicate an insane hookup and 60ft time. ie awd
[Modified by TorteX, 4:23 PM 11/19/2002]
Old Nov 19, 2002 | 01:28 PM
Urban Business
Guest
Posts: n/a
Default Re: question: my crvtec 1/4 mile time (TorteX)
blah 10.1 in 1/8 nm.
thought you were saying you ran a 10.1 in the 1/4
Old Nov 19, 2002 | 04:28 PM
RuffGsR's Avatar
You should be in the 12's.
A CRX Hf the lightest car you can buy. If a HF CRX with a stock B16 hits 13.8 in the 1/4, You should be able to shaved more than a second with the set up you got.]
I'm pretty sure you'll be in the 12's with some good slicks.
Old Nov 19, 2002 | 06:02 PM
Lowness's Avatar
low 13's if you're a good driver
Old Nov 19, 2002 | 06:35 PM
tunedcivic's Avatar
Default Re: question: my crvtec 1/4 mile time (John M)
crvtec should run 12s with a good driver
Old Nov 19, 2002 | 06:40 PM
spettinger's Avatar
Default Re: question: my crvtec 1/4 mile time (tunedcivic)
a CRVTEC should easily go 18.40's on partial throttle. just imagine if you floored it! wow.
ditch the itr flywheel and get a jun/toda/comptech.
Old Nov 19, 2002 | 09:05 PM
EFsleeper's Avatar
Street tires you should pull mid to low 13s, depending on how much your rex weighs and the quality of your tires. You have an HF which is the lightest 2nd gen crx. Slicks I would say high 12s are within reach. Run it and let us know!
Old Nov 19, 2002 | 09:50 PM
ef9jdm's Avatar
i think with some good tires or slicks you'll hit 12's....
Old Nov 19, 2002 | 09:57 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: question: my crvtec 1/4 mile time (RuffGsR)
I dont know who told you that a HF with a STOCK b16 hit 13.8 but they were lying...unless it came stock with nitrous or something. I very rarely see b16'd crx's get out of the 15's...i think you might have meant 14.8?
Sirhatchback:IF you con hook up then you could easily be low 13 maybe even high 12's woth good conditions. I would have to agree that you should spend the money on an LSD. Some stiff *** springs and light 14's with 24 or 25 inch slicks would put you in the 12's easily. Sounds like a beast...cant wait to see the actual times. What type of fuel management are you planning on running? Good luck with it all man.
Sean
Old Nov 19, 2002 | 10:18 PM
crxHF-R's Avatar
Default Re: question: my crvtec 1/4 mile time (sCeRaXn)
I have a B16a and I run 13.40's , I ran 14.60 here in vegas at 2400ft elevation . so somebody dosen't know how 2 drive .
Old Nov 19, 2002 | 11:18 PM
irev210's Avatar
Default Re: question: my crvtec 1/4 mile time (1fstHF)
wonderful... just my luck today guys...
my daily driver, my kia, was K.I.A. (killed in action)
I lost compression in #4 cylinder.... so im pretty screw'd
Im gunna join the dark side and sell all the **** i have and just buy an EK and start over i guess...
all the **** i have is up for sale if anyone is intrested.
Old Nov 20, 2002 | 06:28 AM
Jeff C's Avatar
BTW, that was my first run with it. Its going to take some getting used too.
Old Nov 20, 2002 | 10:50 AM
All_MOTOR_CR-X's Avatar
with stock internals ..intake header and exhaust (the basics) 13.5@103mph street tires...LS tranny ....6 puck... depending on ur driving skills. with a jg head package ... and a built block also ... with a lightened flywheel... 6puck clutch .... individual throttle bodies ..... drag radials LSD b16a tranny ...ill let u know when we run it at the track.
when i had a stock b16a motor with only the basics and a stock clutch ..i ran a 14.7@95mph .... i doubt 13's ..at least not stock .
[Modified by All_MOTOR_CR-X, 7:53 PM 11/20/2002]
Old Nov 20, 2002 | 12:22 PM
dohcsideSi's Avatar
kinda of confuse ...so your dd- the kia bit the dust....why are you selling your crvtec crx????
Old Nov 20, 2002 | 01:39 PM
keebler65's Avatar
Default Re: question: my crvtec 1/4 mile time (dohcsideSi)
yeah really man. just buy a geo metro with a bumper sticker that says "my weekend car is a crvtec crx" then no one will make fun of you but you wont be in debt. keep the rex man, sounds like you've been working on it too long to just sell it.
Old Nov 20, 2002 | 04:17 PM
RuffGsR's Avatar
Sean
We're talking about a 1800lbs car the lightest one.
Here is why i'm asuming this,
B16A
170hp @ 7800 rpm
116lb/ft @ 7300 rpm
8200rpm redline
13.90 seconds
99.4 mph
I think This is true because a friend of mine hits 14.4 with a 90 dx hatch with a stock b16 / street tires , [2103 lbs 300lbs more].
Old Nov 20, 2002 | 04:25 PM
xtrafastcivic's Avatar
an AEM type r CAI will not work in a crx get an injen CAI for a 99-00 Si..... Oversize vavles do nothing on a NA honda car.. <== proven fact.... What made you decide on crower cams??? i haven't heard anything bad or good about them... i would like to see some numbers on these cams.....
Old Nov 20, 2002 | 05:01 PM
irev210's Avatar
Default Re: question: my crvtec 1/4 mile time (XtraFastCRX)
yah i have been working on it too long to just sell it...
Okay, for the oversized valves, it was when I was stupid and i was going to go turbo, but running short on cash, im going to run all motor for now...
I found a solution to fix my daily driver kia while being able to keep my crx and parts, so i will let you know how it progress'
its kinda sexy having a 2000 JDM b20b w/ a factory knock sensor, gotta love the PHK-XO pistons also...
Im figuring with my valves, and my cometic head gasket im shooting for around 10.2-10.5... nothing crazy.
Im going to clay my motor see how much i need to dremel out the valve reliefs.
ill shoot up some pictures of the b20 block later... here are some pics of the head.
Ill shoot up pics of my port and polished R intake manafold soon
[Modified by sirhatchback, 2:03 AM 11/21/2002]
Old Nov 20, 2002 | 05:09 PM
Kin's Avatar
Kin
Mmmm, awesome pictures man can't wait to see the next set. Keep us updated on how everything works out.
Old Nov 20, 2002 | 05:27 PM
irev210's Avatar
Default Re: question: my crvtec 1/4 mile time (Kin)
and the rare jdm b20 in all of its glory
anyone thats 56k i feel sorry for, but im running off my own personal web server which is very fast, so you guys with cable/dsl wont have any problems.
JDM B20B
JDM PHKXO pistons
notice the factory knock sensor
now i want to take the oil cooler off this b16 block and put it on my b20
this is my friends h22, how did this get in here?
[Modified by sirhatchback, 2:30 AM 11/21/2002]
[Modified by sirhatchback, 2:31 AM 11/21/2002]
[Modified by sirhatchback, 2:34 AM 11/21/2002]
