1994 Del Sol - SRS Light
Old Dec 4, 2024 | 08:04 AM
rytomi's Avatar
Default 1994 Del Sol - SRS Light won't go out
I have a 1994 Del Sol S with the SRS light on. I bought it this way recently and so I don't have a history. The car is 100% factory stock. Besides wanting the SRS system to actually work, I also live in Virginia which requires safety inspections and is failing for this reason.
I've searched and found many threads on how to reset the SRS light, as well as how to pull codes, and nothing seems to work for me. Lots of people ask in these threads what to do if the light never goes out, but there's never an answer.
What I've tried:
Resetting the SRS light - Found the yellow 2-pin connector in the fuse block connected to dummy socket. Insert a jumper, turn key to on, SRS light never goes out to start the reset procedure.
Pulling SRS codes - Found the blue 2-pin connector above the passenger kick panel, insert jumper, turn key to on, SRS light stays solid on and does not flash.
Both horn buttons in the steering wheel DO work. CEL is not on after engine start. 109k miles. Factory seats, factory steering wheel, factory original everything.
I'm hoping someone can guide me where to look next for the issue.
Old Dec 30, 2024 | 11:57 AM
rytomi's Avatar
Default Re: 1994 Del Sol - SRS Light
I've replaced the SRS module and there is still no change. The SRS light doesn't go out even if the reset or diag connector is jumped.
Can anyone shed any light on what could be the problem?
Old Dec 30, 2024 | 07:46 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
What SRS code(s) do you have ?
Have you tried the reset procedure ?
Old Dec 31, 2024 | 01:57 AM
rytomi's Avatar
That's the problem. It won't give me any codes when I jump the diag connector on the passenger side, SRS light stays on and doesn't go off. Same when I try the reset procedure, the light won't go off either when the yellow connector is jumped from the fuse block.
Old Dec 31, 2024 | 07:44 AM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
This sounds frustrating!
I have no ideas, but in for the learning.
Do you have DS and PS air bags?
Old Dec 31, 2024 | 08:30 AM
rytomi's Avatar
Yes, I believe 1994 was the first year for dual air bags. I might just replace the clock spring anyway even though it seems to be fine. I don't really have any other ideas.
Old Dec 31, 2024 | 12:15 PM
Premium Member
Loved
Community Favorite
I wonder about disco'ing the battery and then the sensors and the air bags.
Then reconnect...
Old Dec 31, 2024 | 04:12 PM
rytomi's Avatar
Then reconnect...
I actually did all that I believe as part of the control module replacement. I followed the procedure outlined below that I found online as an excerpt from the factory service manual. From my research I think the 1994 has all sensors built into the module.
1) Disconnect battery, wait minimum of 5 minutes.
2) Remove lower cover plate from steering wheel, disconnect air bag and attach red short connector.
3) Remove glove box, disconnect air bag and attach red short connector.
4) Remove center console and plastic housing at center, far forward under dash (behind radio and heater ducts).
5) Disconnect Air Bag Module, and remove the 4 T30 Torx bolts to remove the module.
6) Reinstall in reverse order.
The only thing that changed after this was my CEL now acts differently for some reason. Before, when I turned the key on but did not start the engine, the CEL would illuminate and stay on until the engine started. Now, when I turned the key on but do not start the engine, the CEL comes on for a few seconds and the turns off. Also stays off when running. The diagnostic connector and SRS reset connector both still fail to extinguish the SRS light after the specified 6 second interval to reset or pull codes.
Old Dec 31, 2024 | 09:41 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Resetting the SRS system utilizes the yellow two-wire connector found on the face of the under-dash fuse box. There is a process using a jumper/connector over a specified amount of time... shorting the connector, then unplugging, then shorting again, then unplugging again, etc. until the SRS light flashes 3 or 5 times... anyway, this process is found in the FSM. You do NOT check SRS codes with the service connector on the passenger side kick panel... that location is only for engine codes. You will use the yellow SRS service connector on the under-dash fuse box and the SRS light will blink the stored codes. If you have ever unplugged an airbag, you WILL have a stored code.
Old Jan 1, 2025 | 06:38 AM
rytomi's Avatar
This yellow SRS connector is the one I use to try to reset the light. When I jump the connector, the light never goes out, it stays on solid. I couldn't find any excerpts from a 1994 FSM, but based on what I found on a 1996, it explicitly says the connector on the right passenger kick-panel is used for retrieving SRS codes vis flashing SRS light. But again, no matter which connector I use, the light doesn't go out or flash, just stays on solid.
Old Jan 1, 2025 | 07:57 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Check the two fuses located at the SRS fuse block, to make sure one of the fuses is not blown.
Check the ground wires and ground connection at G801 for the SRS module.
Old Jan 1, 2025 | 08:27 AM
rytomi's Avatar
My fuse block only has one labeled as SRS, it's a 10A and I checked and even replaced it as the first step. I've manually tested every fuse in the block and they are all good. The ground at G801 I can also say with confidence is good as I also double checked that when I did the module replacement.
What's interesting is the second fuse your image shows should be a 15A, but the only 15A fuses shown in my fuse block label are 1 spare, the Radio/Cigarette Lighter, and two labeled as ACG (S), which I have no idea what that means. One of the ACG (S) is located next to the SRS fuse and is probably that other SRS fuse and has a good 15A fuse in it. The other is on the far left and has a plastic plug in the socket instead of a fuse, though your #40 picture also seems to show the same. The connector circled in the red is the one I try jumping but the light doesn't go out.
Curiously, I see the note on your first image mentioning 1994 models with SRS retrofit. My 1994 is a very early 1994 model manufactured in 1993, so not sure if this relates somehow.
TonyRomo
Jun 23, 2008 08:02 AM
85ascMcLaren
Apr 18, 2008 05:01 PM
USDM.LOVE
May 21, 2007 05:04 PM
Slvr_CRX
Oct 23, 2004 05:36 PM
DumpedSi
Sep 11, 2003 08:42 PM
