I have a 2000 Honda Civic VP with 160xxx miles I’ve had the car roughly 2 years never had any issues other than a stopped up radiator that caused over heating was mechanically sound before no start issue arose.
it drove fine on my way home from work, got in the next morning it would crank but no start and oddly if I held gas pedal to the floor it would try to run on what sounded like 1 cylinder even disconnected all plug wires through process of cranking and only 1 cylinders ignition made a difference in it trying to start( no longer fired on the 1 cylinder). Checking timing all tdc marks were good went ahead and changed anyways, changed distributor as well. Long story short I have spark on all cylinders, I have fuel(starting fluid makes no difference), I have no codes, and compression on all cylinders was within 140-150 psi where do I look now?
