Help
Your Electric Load Detector has failed. The ELD is located in the under hood fuse block under two maxi fuses. Each ELD is model and sub-model specific. You can find used ones on eBay all the time, just make sure the part number and plug style matches your old one.
There was a Honda service bulletin many years ago. Fuse No. 15 is likely blown; this is usually due to a short in the engine wire harness rubbing a bracket or the wiring for the O2 sensor.
There are many threads about this.
