Not starting after replacing Micu
I am about to put the f****g car on fire.. I replaced the MICU thinking it was causing an issue with one of the door lock actuators, but now it is not starting (nor the door lock works).
I have registered the MICU correctly, and I get no green light flashing or is fixed in the dashboard. I have also registered all keys again.
Look like if the fuel pump isn't running, but I am not entirely sure. There are no DTCs reported... When I go to IMMO and Status log, I see an entry "C1" with a number 2 next to it (not increasing or anything).
If I try to reregister the PCM/ECM, it always fails with a generic Failed error.
I have inspected the Fuel pump fuse, and it is fine. Also in HDS I can turn on the Fuel Pump relay and I can hear the relay clicking, but I think I am not hearing the fuel pump. Does anyone know which pin to check for power?
Any idea on what else to test/check? I would be extremely thankful. Thanks!
Roger Denton
Apr 15, 2019 05:53 AM
