Honda CR-V & Element 2WD & 4WD Element & CR-V
04 CRV Auto to manual Conversion
Old Nov 19, 2024 | 10:52 AM
K24 CRV's Avatar
Default 04 CRV Auto to manual Conversion
Hello team. New on this page
I'm trying to get some help from the more expert people here. here is the thing
I just did a Auto to manual Swap on my CRV (using an Element manual transmission)
mechanically got everything done. but I cant start the thing ( dash board shows transmission on Drive)
I still have the Auto ECU and I have no clue what wires and locations for them I need to put together to bypass the Neutral switch
Any one has done this before and if you could share information that would be fantastic
I'm a very visual guy so I photo or 2 would be greatly appreciated
thanks in advance for the help
Old Nov 19, 2024 | 11:12 AM
Chrisfrom1986's Avatar
Default Re: 04 CRV Auto to manual Conversion
Jump the neutral position wires in the auto shifter plug.
Old Nov 19, 2024 | 01:23 PM
K24 CRV's Avatar
Hello Chris
thanks for the prompt response, but like I'm not familiar with the harness
where is the Neutral wires ( what colors and how many should I connect)
the Auto shifter pug is on the transmission pugs the ones that are no connected any longer.
its my 1st swap so I'm not really familiar with a lot of terminologies
Old Nov 22, 2024 | 05:56 AM
Smackin's Avatar
5 Year Member
Loved
Community Favorite
Sounds like a cool swap.
Maybe interested in the starter cut circuit indicated here?
2002-2004 Transmission range switch
Old Nov 22, 2024 | 07:17 AM
K24 CRV's Avatar
Hello Smack
Thanks for the support and the diagram will do the changes make the changes so I can get the car running I will share photos of my process in case any one has questions regarding this Swap
I got an Element M and I added the 6th gear and bought a LSD Kit for the Differential.
the shifter was a pint on the butt to figure out (Installation)
since there is not really a write out. I have to get creative I see the CRV is not really a popular car for Transmission Swap or we don't leave any records for others that try it.
well I will get some Photos once I get the car Running
once again thanks for the diagram
Old Nov 22, 2024 | 02:31 PM
According to the diagram the neutral position is the red/black wire. Take the auto shifter plug and connect that wire together with the black ground wire and it will always be in neutral.
Old Nov 22, 2024 | 02:45 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The starter cut relay circuit like Smackin mention should be jumped to bypass the transmission range switch (neutral switch). So the Blk ground wire needs to be jumped to the Blu/Wht wire going to the starter cut relay.
speedfreak44
Nov 26, 2010 06:28 AM
blink_977
14
Feb 28, 2009 07:58 AM
akces
Oct 19, 2008 09:59 PM
hondaACCORD
Apr 10, 2004 11:29 AM
