b18c1 swap, wont go into gear help pls
Old Nov 18, 2024 | 12:45 PM
Diego P's Avatar
Icon4 b18c1 swap, wont go into gear help pls
Hey guys so i swapped a gsr engine and trans into my crx and i have a cable to hydro clutch actuator and when i have the car running i cannot put it in gear. I can put the car in gear fine when the car is off but as soon as its running i cant get it in gear. i adjusted the actuator to be what seems like fully sticking out so im pretty sure its getting pushed fully but i still cant get into gear, please help and give me any sort of advice than you.
Old Nov 22, 2024 | 02:11 PM
Diego P's Avatar
Default Re: b18c1 swap, wont go into gear help pls
Hey guys so i figured out the issue, i took the trans out and the throwout bearing was not properly on the clutch fork, but then i started getting the same issue when i realigned everything, but i figured it out finally today, the issue is that the clutch actuator was pushing the throwout bearing way too hard, so when i pushed the clutch in halfway it woud go into gear fine, so i just have to adjust my clutch actuator goodluck everyone lmk if you have questipns
Bentley454
Transmission & Drivetrain
Mar 4, 2013 08:10 PM
beastsohc
Jan 18, 2009 05:08 AM
HONDRETTI
Nov 26, 2007 12:20 PM
zexhuffer
Feb 14, 2006 07:18 PM
gtowni3
Nov 26, 2005 12:02 PM
