1995 Honda Civic LX Sedan : ISSUES // HELP
Own A 1995 Honda Civic LX Sedan
126xxx Miles
1.5L
Automatic
Car was running fine, then while driving it died out. car would start right back up and run.
It did it a few times over the course of about a week or two. but would happen randomly, it would die out then start right up and run fine until the next episode.
then finally died out and won’t start back up.
It will crank but won’t turn over.
replaced:
alternator
fuel pump
main relay
reset ECU
still nothing.
126xxx Miles
1.5L
Automatic
replaced:
alternator
fuel pump
main relay
reset ECU
still nothing.
maybe we should look more into the ignition of things, such as:
distributor cap/rotor
spark plugs & wires
im not an expert, this is just my opinion.
i also found this post here: https://honda-tech.com/forums/honda-...2A%2A-1992733/
good luck friend
spark plugs & wires
good luck friend
update:
so far replaced.
alternator
fuel pump
main relay
ignition switch
and spark plugs
got the car started today and drove it for a bit and after a few minutes it stalled, started back up and drove it back home.
started the car again and it shut off at idle and now will crank but won’t turn over.
so far replaced.
alternator
fuel pump
main relay
ignition switch
and spark plugs
808BOMBSQUAD
Nov 9, 2024 10:03 PM
1sik_90hatch
Dec 18, 2017 09:01 PM
mzao-br
Sep 3, 2014 11:07 AM
