2002 CR-V window control
My 2002 Honda CRV drive's side window does not operate, it did work normally until some dummy we won't name left the sunroof open and rain came in, it took a few days to get dried out.
That may not have caused the problem but it was just after that the problem started.
I could for a while get the window to operate a little, then I could open it using the control switch but it would close by itself. Now it does not operate at all. The controls work for the other three windows.
Would that be the control panel with all four windows control switches etc. that need replaced or is there something additional?
It could be the switch itself going out - or the window regulator motor.
You can take the switch out of the door and jump power directly to the regulator motor to check if it works. You’ll need to check which pins though.
I’ve replaced both years ago when I got rain into the car.
cory.colt
Nov 24, 2022 10:33 AM
colinIG
10
Apr 24, 2013 12:31 AM
maxxedsx
Mar 8, 2006 06:01 AM
