B20B With GSR Head Questions
Just got a 00 GSR head for my 96 B20B and i was wondering what else i need. i want to run my stock bottom end before i build it. i have 96 ek hatch
Currently have
- Golden Eagle Conversion kit
- ARP head studs
- ACL Oil pump
- OEM Gsr water pump
- Gates Timing belt
What ECU do i need for this to run other then hondata?
Currently have
- ARP head studs
- ACL Oil pump
- Gates Timing belt
I’m in process of building mine and this thread helped me out a bunch.
https://honda-tech.com/forums/all-mo...0vtec-1676914/
Currently have
- ARP head studs
- ACL Oil pump
- Gates Timing belt
Currently have
- ARP head studs
- ACL Oil pump
- Gates Timing belt
Nope. You have added 11% more displacement and the computer has no idea that you installed a B20 shortblock under the GSR head. Could you crank it up and let the engine idle with a GSR ECU... sure. Should you do any WOT pulls with the GSR ECU plugged in... the engine will be really lean, so proceed at your own risk.
