Ek spitting fuel
Old Oct 13, 2024 | 05:40 PM
arayam1624's Avatar
Default Ek spitting fuel
Like the title says my hatch is spitting fuel while filling up. I cant get more then $1 in fuel and starts to spit fuel. I’ve replaced the fuel tank the filler neck the evap system purge valve I even open the fuel sending unit thinking some back pressure was the cause and still nothing. Any help will be greatly appreciated.
Old Oct 13, 2024 | 06:25 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Ek spitting fuel
Did you run the gas to about empty? It may be air suction due to the pressurized system
Old Oct 13, 2024 | 06:48 PM
arayam1624's Avatar
Not while I’ve had the car. I bought it as a project car. But maybe the previous owner did. If he did how do I fix this problem.
Old Oct 13, 2024 | 06:51 PM
NVturbo's Avatar
O.G. triple O.G.
You didn’t even stated what kind of mods or other issues it may have
it can be the EVAP canister, pinched fuel neck, etc
Old Oct 13, 2024 | 07:21 PM
arayam1624's Avatar
no other issues or mods. D15b7 engine, put a vapor canister on cuz it was missing one, put the exhaust on and drove it around the block went to put gas and that when the fuel spitting happened.
Old Oct 13, 2024 | 08:32 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
This has only happened with the new fuel tank ?
Old Oct 14, 2024 | 08:53 AM
arayam1624's Avatar
Yes is only doing it after I install the new tank. Reason for the tank replacement is because the old one had a hole in it.
Old Oct 14, 2024 | 09:06 PM
JRCivic1's Avatar
10 Year Member
Community Builder
There is a possibility that the vent hard line inside the tank is too close to the bottom of the tank. This causes fuel to come back up the fill neck as though the tank is full.
Brokenfitting
Feb 12, 2023 09:10 PM
Dominic-CTR
Oct 24, 2004 04:08 AM
laughinxxx
Nov 14, 2001 10:25 AM
