Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Fuel Pressure Regulator for 2004 Civic
Old Oct 13, 2024 | 06:29 AM
c1jkm's Avatar
Default Fuel Pressure Regulator for 2004 Civic
Hi, I have a 2004 Civic that smells of gasoline on the outside of the car after driving. No leaks are obvious. I see where a common cause can be
the fuel pressure regulator. On my car this is located in the fuel pump assembly in the gas tank under the back seat. My question is:
Do I have to replace the whole fuel pump assembly or can just the regulator piece be replaced separately?.
Old Oct 13, 2024 | 09:15 AM
c1jkm's Avatar
Default Re: Fuel Pressure Regulator for 2004 Civic
I checked the pump housing. It is not cracked but it looks like the seal has failed. It is pretty wet in there when I removed the plate.
Even though it is in the gas tank I assume it should be dry around the top of the pump. Is this correct? I also assume I will have
to replace the whole assembly unit. Correct? Thanks.
Old Oct 13, 2024 | 04:41 PM
c1jkm's Avatar
I have decided to replace the whole assembly. Better to be safe than sorry.
Old Oct 13, 2024 | 08:02 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Both the seal and the regulator can be replaced without replacing the entire fuel pump assembly. The fuel filter is within the fuel pump assembly... if your car has high mileage, replacing the entire assembly may be a good idea.
Old Oct 17, 2024 | 04:30 PM
c1jkm's Avatar
I replaced the fuel pump. All went well. But now, a few days later, my gas gauge shows empty and my gas light
is on. I have plenty of gas in the tank. I will open it up again, but if I can't seee anthing obvious, can I
use the car, keeping track of miles driven to fill up after driving say 150 miles? It is a 2004 car and I can
live that if it won't damage anything>
Brayneeac
Honda CR-V & Element
Dec 22, 2017 03:15 PM
hbyrd8701
Aug 16, 2007 09:07 PM
baby50
Oct 11, 2005 07:50 AM
Simple
Jun 20, 2003 07:33 AM
