Ecu p06
Old Oct 12, 2024 | 03:58 PM
earth sloth's Avatar
Default Ecu p06
So i have gotten a new ecu is a p06 and for what i saw (im still a bit of a noob on this) i think my ecu is chipped but im not quite sure if it really is, could somebody help me
Old Oct 12, 2024 | 08:26 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Ecu p06
It IS chipped... the question is what calibration is on the chip ?
Old Oct 13, 2024 | 02:30 AM
Default Re: Ecu p06
bro idk. The ecu works fine, the car is running fine too. But what i wanted to know is that if i can simply change the chip (to a sst) and make some extra connections to connect it to my laptop?. Thing is that i watch a video where a guy chipped a p06 too and he does diffrent connections compared to my ecu so idk 😅
Old Oct 13, 2024 | 01:27 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Ecu p06
Since the ECU is already socketed, you can upgrade to a piggyback system like Hondata or Neptune RTP.
Old Oct 13, 2024 | 08:17 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Default Re: Ecu p06
You asked if the ECU was chipped but you weren't sure... my response assured you that the ECU is in fact chipped. You CANNOT burn a chip while it is installed into the socket of the ECU. With the proper devices and software, you can create calibrations on your laptop and then burn them to a reprogrammable chip like an SST 29C256, but the only way to do it live is to use a device like a Hondata S300 or Neptune Demon.
Old Oct 14, 2024 | 04:18 AM
Default Re: Ecu p06
well thank you very much fam this is actually the answer i needed
Old Oct 14, 2024 | 08:55 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Default Re: Ecu p06
Remember that the "socketing" is different... the socket is female for a chip; the socket is male pins for a Hondata S300 or Neptune Demon board. Converting from a "chipped" ECU to a Hondata S300 ECU will require some board modifications.
Old Oct 15, 2024 | 12:01 AM
Default Re: Ecu p06
I looked for some vids and the cheapest and easiest way for me is to use a sst chip and a devmo ft232rl. will that work too?
Old Oct 15, 2024 | 05:25 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Ecu p06
my bad. That’s what I meant
Old Oct 15, 2024 | 10:18 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Default Re: Ecu p06
No worries. I have posted erroneous information a time or two myself... we are both human... with good intentions.
