Help with parasitic draw
Hello everyone! I recently purchased a 2015 civic for my 17 yr. old son. It sat in my garage for a couple of weeks while I was waiting for the title so I could register it. The battery it had in it was 1 year old. After I registered the car and got insurance, I went to drive the car, and the battery was dead. I used jumper cables and got it started and drove it around. However, if the car sat overnight with the battery hooked up, it would not start. If I left the battery unhooked overnight and then hooked it up the next day, it would start up fine. I used a meter to check for a draw. It is showing around 260ma draw. I went ahead and replaced the battery and checked the alternator just in case. I have been troubleshooting the draw to try and figure out where it is coming from. If I remove fuse A-29 "Back Up" from under the hood, the draw goes away. Also, if I unplug connector "Q" from behind the interior fuse box, the draw goes away. I am trying to locate center junction box 2, in order to unplug it however, I haven't been able to locate it. Any info on where I can find this junction box? Also, any ideas on what may be causing this draw? I do not have any aftermarket accessories installed. Any help at all would be greatly appreciated! I have watched a video from Hektor on youtube but it doesn't really show where the junction box is located.
Thanks!
Andy
Thanks!
Andy
I found the Keyless Access Control Unit and unplugged it, and the draw went away. I hooked it back up and went the front doors. I unplugged the door lock actuators, and the draw was still there. Then, I unplugged the door handles and if I unplug both front door handles the draw goes away. Does this mean both door handles are bad? Or is it the keyless access unit? Any ideas?
Thanks!
Thanks!
butter99
Jul 27, 2009 11:59 PM
stocker2shocker91
Apr 28, 2007 07:23 AM
braypunt
22
Sep 11, 2005 09:10 AM
CimorelliCRX
12
Dec 27, 2002 07:40 PM
